I'm working with Creo Parametric 6.0 and I am trying to blank out components in my drawing but I am unable to select the desired component. When I try to unblank components the same component becomes visible regardless of which component I try to select but disappears when I select OK. This happens regardless of which drawing view I try to work with. I am at a loss here, can someone think of anything I should try?
Tried: Select Blank & All Views > Select Components in Model Tree > Select OK
This hid the component in all views, not just the one I need it hidden in.
