Cabling references
JimBarrettSmith
Cabling references
At Planet PTC I had several customers ask me about removing cabling assembly references. PTC enabled the ability to remove cabling assembly references in Wildfire 4.0
There are two options.
Option one
  • Create a shrinkwrap \copy geom
  • Set configuration option freeze_failed_cable_locations to Yes
  • Route the cables referencing the copy geom
  • Delete the copy geom - the locations will then freeze
  • From within cabling Locations > Covert to offset - Use CTRL + F to find and select all the frozen locations
  • Select an assemblycoordinate system - all the locations are then offset from the selected Coordinate System
Option two
  • Route all you cables using any reference you want
  • From within cabling Locations > Covert to offset - Use CTRL + F, In search tool Select status tab, and set"is not equal to""frozen" to find and select all the locations
  • Select an assembly coordinate system - all the locations are then offset from the selected Coordinate System
In both options I recommend you set the configuration option freeze_failed_cable_locations to Yes as this will make sure you harness is stable during design changes.
I trust this information is helpful, if not then please let me know
Jim
0 REPLIES 0
