Calculations in Repeat Region
ptc-1192223
I'm trying to create a bend machine table for a tube, and would like to report the protractor setting rather than the twist angle. The protractor setting is just the sum of the twist angles up to the current bend. Is it possible to perform calculations on the members of a repeat region and report the results of the calculations in a different column of the same repeat region?
I've tried to do this using relations, and I can see a parameter for each column of the repeat region, but Creo states that it is an unknown data type, and it doesn't look like you can access the individual elements, just the column itself. These parameters are named like __RPTSYM8
Here's what I've got:
Bend Twist Angle
1
2 60
3 10
4 30
Here's what I'm after:
Bend Twist Angle Protractor
1 0
2 60 60
3 10 70
4 30 100
ErikClacey
(To:ptc-1192223)
I've got the same problem and I'm also looking for a solution. Have you found a way?
