Calling up Number on drawing
fred_roy
Hi everyone,
WC8.0, WF3.0
Is it possible at all to call up the Number on a drawing? We typically
call up the File Name but I want to change that to the Number.
I looked on the forums but I can't find any topics on that.
Jean-Frederic Roy, M.Eng, P.Eng
Sr. Mechanical Designer
SPIELO
Phone: 506.878.6460
Fax: 506.852.7640
CONFIDENTIALITY NOTICE: The contents of this email are confidential
and for the exclusive use of the intended recipient. If you receive this
email in error, please delete it from your system immediately and
notify us either by email, telephone or fax. You should not copy,
forward, or otherwise disclose the content of the email.
If you are just looking to report a specific parameter in the drawing
format sheet as the part number, it can be done with any parameter in a
straightforward manner.
Look for &<param name="> where <param name="> is the defined parameter in
the drawing or active part when the drawing is created.
BTW, in a drawing with several parts active. Make sure to active the
proper part before creating / replacing a drawing format on a sheet to
pick the right report parameters to populate the title block.
If you are using a default template to create parts, you can also create
the drawing automatically with the same name/number from the templates.
For example, our parts and drawings do not have the same name as the
drawing (legacy issues), so we create a parameter at the part level
called 'SK', and then in the title block of the drawing we show '&SK' to
report the part number. This also goes for BOM's
I hope this was useful,
Christopher Gosnell
TRIGON INC.
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
PH: 724.941.5540
FX: 724.941.8322
www.fpdinc.com
Actually, what I'm trying to do is call up the actually Number (which is
a Windchill field I believe) in my drawing.
Here's more background info:
I am working on a new family table for fasteners. In order to make it
simpler to call up fasteners in our assemblies, I want to use a
descriptive term for the File Name. Since that fasteners is going to be
used in BOMs, it still needs to have a Number. I want to be able to call
up that Number on a drawing.
Does that make sense?
Anyway, thanks for the help.
Fred
Hello again,
I'm trying another angle for this issue... Is it possible to add
PTC_WM_NUMBER in my part or assembly parameters?
If so, how would I do that?
Fred
