Hi @AT_CADDM ,
You can add individual hyper links to text displayed in the repeat region table only if the cell is defined as a ‘Comments’ cell. Otherwise, adding the hyper link to the first cell contents would repeat it to all the cells in that column.
A commented cell allows the user to type in required custom text and does not repeat the same for other cells of the column. So, you could type in required text (remarks) for each cell separately. Also, the commented cell is attached to the row. So, if the row position changes, the commented cell will automatically move along with it.
To define a comment cell in existing repeat region, follow the procedure given below.
Mac
Hi @AT_CADDM ,
Mac
