Maybe you have the option intelligent_fastener_enabled set to no. in config.pro file or either in config.sup.
If so, then set it to yes value
The IFX license is an option and costs extra. Creo 3+ comes with a basic IFX license, but you cannot modify anything with files supplied.
Not necessarily. In latest Creo Design packages full IFX is bundled with a base Creo Design Essentials package (along with some other extensions like AFX or Cabling & Piping). It's an extra extension only if you have some older packages and not upgraded them to Design Essentials or higher.
Dear customer,
As previously said, you need a specific license to access the IDX module from Creo Parametric.
Please can you check if such license is available in your Creo 4.0 session :
> File > Help > System Information > Configured Option Modules , then check if IntelligentFastnerExtension is listed.
Waiting your information
Cheers
Sorry for the typo , I mean IFX
To check the installation, browse to Common Files folder and confirm the ifx folder is present.
Another way is to run set-up again.
