Color Library - WF4
LeeCasey
2-Explorer
Color Library - WF4
Hi, in WF3 I used to have my syscol.scl in its specific dir location or in the startup dir location and I would get a nice library of my colors to choose from when rendering etc. However, in WF4 this dosnt seem to be working for me? Has something changed? Any tips on how to get a nice pre-defined color library? thanks Lee
Wildfire 4.0 uses a file called appearance.dmt You can name this file anything you want as long as you point to it from your config.pro Make sure you add this config.pro option to your local user config.pro pro_colormap_path <path to your apprearance.dmt file> You need to save the .dmt file from Pro/E when you are inside the model color dialog box. When ever you choose to save file, it will assign it a .dmt extension and you must put this file where the config.pro option is pointing too. I have a very nice .dmt file you can use with many colors and labels for each. I attached it to this post.
Fantastic! Thanks very much!
