All,
I have an assembly i am running an analysis on. It consists of an inner race, outer race and a key between the two locking the two together in a certain direction. I want to apply a torque to the outer race that will transfer theload through the key and into the inner race.
My question is, how would one set up the contacts and constraints for this. I applied contacts around the keybut when i run the simulation it says the model is unconstrained, but if i constrain the key it seems like it would be fixed and would'nt act as it should. Should you need both contacts and constraints, i just want the key to "float" between the two races until contact is made with the inner race.
Any thoughts?
Brad
If that still doesn’t fix the problem post back and I will take a closer look.
Stephen Seymour, PE
Principal Engineer
Seymour Engineering & Consulting Group
<u>www.seymourecg.com</u>
