Convert Internal Datum to Standalone / Embedded Datum
akelly
Currently using Wildfire 4
Using a pre-Wildfire part where features were created with "make datum" during feature creation. These datums don't show up anywhere in the model tree / layer tree / screen, even if I have performed Unhide All, expand all, and set all layers to unhide. If I Edit Definition on the feature then go into Sketch Setup, I can see the plane, but otherwise, I'm unable to pick it.
According to the Wildfire 4 help, these are called "datum features that are internal to a feature". Is there any way to convert these to regular datums? (or, at least make then visible, selectable, etc.?)
Note: I brought up help because it discusses embedded datums and how to convert them to standalone datums. This isn't an embedded datum. I guess pre-Wildfire didn't create explicit features when asynchronous datums were created.
Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics | +1 440 326 5555 | F: +1 440 284 1090
akelly
(To:akelly)
In other words, DTM2 exists, but it is not visible in the model tree (or screen), because it is internal to Sketch 3 (see attached).
I want to convert DTM2 to the way it is shown in the attachment.
<<embedded datum.png=">>
mpeterson
(To:akelly)
Not the answer to your question, but one reason I very rarely create datums on
the fly. If I realize I need a new datum I will exit the feature creation and
create the datum and then proceed with making my feature. If need be later for
mirroring, patterning orcleaning up the model tree Iwill group it at that
point.
Good Luck withthe resolution to this issue.
Mark A. Peterson
Sr Design Engineer
Igloo Products Corp
JOES
(To:akelly)
Just yesterday I bumped into the same issue. I couldn't make DATUM A
because A was taken. Using Locate found it buried in a pre-WF feature. It
was a revolved cut that cut nothing. I could repress it, move it anywhere
on the model tree but I could not delete it. Finally I was able to rename
the datum to Z & create my new, stand-alone DATUM A.
As I remember, a feature has no delete option if part of that feature, like
a datum, is used in the drawing of the part. Nothing shows whatsoever on
the drawing so it must be something else. No worries, I work-around works
but I dislike leaving that feature at the suppressed at the end of the model
tree.
Joe S. 313 410 9034
On Mon, Mar 28, 2011 at 2:08 PM, Kelly, Andrew C <
> it.
> created.
> Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics |+1 440 326 5555
> | F: +1 440 284 1090
