Coordinate system regeneration problem
VM_10202801
I am using Creo Parametric - Release 5.0 (connected) Release 5.0 and Datecode5.0.5.0
We meet a problem while regenerating a coordinate system driven by relation, the dimension is updated but the CS doesn't update. I have already tested in Creo 8 I have the same problem
tbraxton
22-Sapphire I
(To:VM_10202801)
Not enough information provided to investigate the root cause. You will need to provide more details and preferably the model with the problem or a simplified test case model.
Involute Development, LLC
Consulting Engineers
VM_10202801
(To:tbraxton)
Hello, I'm sorry I wanted to open a case and I made a mistake, anyway, after discussion with support, the CSYS is maybe corrupted, thank you for your reply
StephenW
(To:VM_10202801)
As @tbraxton  says, you will either need to provide more info or attach the model to get any help.
With respect to relations, depending on where your relation is, you may have to regenerate twice to get the desired result. But without any information, we have no way to helping.
VM_10202801
(To:StephenW)
Hello, I'm sorry I wanted to open a case and I made a mistake, anyway, after discussion with support, the csys is maybe corrupted, thank you for your reply
