I made a part by referencing an external copy geometry. I try to hide this copy geometry after the part is created, and Creo says the geometry is hidden, but it is still visible in my model. I need to get it out for a drawing.
Try this in your part model:
Create a layer for the copy geometry feature and add the copy geom to this layer.
Hide the layer and save layer status in the model.
Save the model.
Open the drawing
Hide all layers in the drawing (you do this in drawing mode). The copy geom should not show up in any drawing views after hiding the layers.
Save the model.
Open the drawing
