Crashes when I try to open Simulate
ltambellini
We are modelling an airplane body and right now we have a problem where every time we try to open simulate, CREO completely crashes with no error messages or anything.
We believe it may be something about the material properties, because we tried to make one. When we were constructing the wing, we did it using surfaces and boundary blends that we added onto a part file that originated from a step file from another program. Then, we've been going into Simulate and adding shells and thickening them. All of a sudden, the Simulate button stopped working and now it crashes immediately when we hit simulate every single time. We have tried using different computers, and restarting computers to no avail.
We found someone who had a similar problem, but we couldn't fix the problem based on the article. Here is the article:
https://community.ptc.com/t5/Analysis/Simulate-crashes-on-startup/td-p/168695
Can anyone help us fix this????
Louis,
If you are in active maintenance submit a ticket for PTC Technical support to report the exit
