Creating flaten harness when there is no common location
ptc-4428911
I'm fairly new to Creo cabling and right now is working on flatten harness.
My harness part is simply two connectors, no common location except for from/to different pins between two connectors plus a bundle
I tried to use autofan and manually to lay out - both weren't able to be flatten into one plane rather than floating in the space
As well, I'm not able to move segment for a single wire, it shows "Selected entity is not a line. Select again".
Does anyone have encounter this type of problem and know how to deal with it? Thanks!
0 REPLIES 0
