I’m trying to do a zone view on a large assy. I got the zone view to pop on the drawing but my BOM balloons are showing up everywhere when I print. Looks correct on the computer. Any ideas.
Hello Tom.
Can you provide some images of the problem? Screen shot in the application compared to the output of the print?
I don't use zones for views but I suspect there is a limitation in this.
Of course, you can always open a support case to report what you may consider to not be working as expected.
Thanks Antonius. This is a sample of what's happening. I created 2 zones on seperate sheets and
identified BOM balloons on each of the views. I think it's picking all the balloons and showing them on
both views as well as the BOM page which has no views attached.
Oh now that is a new one
It may be difficult to get WF4 support.
The fact that is printing stuff not visible is problematic. I know Creo has a switch to only print visible objects. You might look for that in your WF4 print settings.
I have never likes associative ballooning from a BOM. Maybe this was one of the reasons I didn't like it, I cannot remember. Personally, I like managing my BOMs manually and placing balloons manually. I'm an old world drafter so I have no trouble confirming the correctness of my work when checking the BOM against the find numbers, and I also know they won't change on the next iteration.
