Creo 9 won't launch in Windows 11 Parallels
  • September 5, 2024
  • 1186 views
I need some help to launch Creo 9 on Windows 11. I use a VM with Parallels because my laptop is a MacBook Pro M2Pro 16gb RAM. My VM has 8 cores for the CPU and 10gb RAM.
2 days ago I installed Creo 9 because I will use it for my 4th semestre as an aeronautical engineer student in Bordeaux's University (I'm French so my English isn't perfect). I installed with success the folder that the university has given to us called "MED-100WIN-CD-460_9-0-0-0_Win64", extracted it, launched the "setup.exe" files, put my key licence and dowloaded everything. Then I have tried to run the file "Creo Parametric 9.0.0.0" but nothing happened. Just my cursor tell my that is loading during 1 second (you know like when you try to launch something on Windows the cursor does a blue loop to tell you that it's loading) and then nothing happen.
Can you please tell me what I have to do to launch Creo ? Don't worry I will use it in January so it's not urgent but I wan't to know the basics to work something else in my 4th semester.
My best regards,
If you did a simple search for "Running Creo with Parallels" you would get the following:
https://community.ptc.com/t5/System-Administration/Running-Creo-on-MacOS-via-Parallels/td-p/910478
I have never been able to get Creo to run this way, and I don't know anyone who has.
