This is a map showing the options available in WF 5/ Creo Parametric. Not sure why I included 'Delete Layers' three times. I'll fix it when I find the Dia format file, and then post that and an SVG file for use on Web pages.
With this map you can look for a function you want to perform and track back to how to get there or use it as a checklist to see the functions you know about vs the ones you don't.
The blue areas are those that don't dead-end on this map or are mode-dependent, but lead to other functions.
This is the sort of map I wish PTC would provide so that one can see the relationship between the functions that are available and the paths that are required to get there.
Nice work!
Just today I was having trouble with little quilts related to welds. They were a simply little add-on that permiated several levels and drawing. There's got to be an easier way.
