guys;
a couple of employers ago, i was at a company that used Pro. to add a revision to a drawing, you could insert a pre-made table that had the fields already set up for revision, description, date, author, etc. i remember that when you inserted it, you could select how many lines you wanted it to be, so if you had a lot of stuff to document, you could have the appropriate amount of space to do it in, i.e. multiple-lines to type in all the changes for the revision.
i'm at a different company; we just bought Creo and i'm the one doing the prep work of setting this stuff up. my question is: how do i set up the table such that you can select how many lines it is when you insert it? i've browsed through the table stuff and its not quite apparent to me. a quick search of the help didn't do much, either. i also looked through the stock tables that ship with Creo.
if anyone has any tables that are already set up for this (or are close that i could modify), that would be great.
thanks,
-eric
