Creo starts normally but nothing displayed in work window.
ptc-4754546
Just installed Creo 1.0 (educational edition) as part of my course. I'v installed this on a partitionrunning Windows 7 professional on my Macbook Pro (2011 model) Creo starts normally however when a new part is started absolutely nothing is displayed i.e. planes etc, when a sketch is started still nothing. When a saved part is opened within creo again nothing is displayed. Any suggestions as to what the problem is in this case and if there's a solution?
Thanks in adavnce
JoshH
(To:ptc-4754546)
Hi Noel,
while Mac's aren't supported hardware for Creo, I've seen it run with BootCamp and probably one or two other ways.
One thing that may help is to set your graphics performance to win32_gdi
Go to <File>, <Options>, <Configuration Editor>, <Add...>, Graphics, win32_gdi
Good luck,
Josh
JoshH
(To:ptc-4754546)
Hi Noel,
Good luck,
Josh
Hi Josh,
Very helpful. That has the problem sorted.
Thank you,
Noel
