All,
This is a pretty specific question (and maybe a bug), but I'm hoping
someone has seen it.
I have a drawing with only one view on it using a simplified rep. This
rep excludes a number of parts from my assembly that are not needed for
the drawing. My assembly has family table instances and I can manually
#DRAWING MODELS #REPLACE to choose another instance and the new instance
regenerates just fine. "Just fine" meaning it doesn't regenerate the
parts I've excluded.
The problem: as soon as I try to incorporate this sequence into a trail
file, the new instance regenerates all parts of the assembly, even the
excluded ones, as if there was a master rep on the drawing. The only
rep on the drawing though is the simplified rep. Any ideas?
Thanks in advance,
Tyler
