Dashed lines does not print on PDF properly
GR_6261265
Hello PTC Community,
I have issues to print hidden lines on drawing module, i export to PDF and hidden lines appears as continuous linemaking drawing confuse, any of you can guide me what to configure to fix the issue?
kdirth
(To:GR_6261265)
Try this config:
intf2d_out_pdf_scale_line_fonts no
We had the same issue after upgrading to 4.0 M130
6 REPLIES 6
1.] what command sequence do you use to produce PDF ? (attach pictures if necessary)
2.] what config.pro options did you set ?
Martin Hanák
Hello Martin,
Thanks, I use FileSave AsExport and then it creates my PDF file, which I can then send it to printer.
And in config.pro last changes I did was to set the folling options to "yes"
pdf_use_pentable→Yes
use_8_plotter_pens→Yes
See attached file.
@GR_6261265 wrote:
Hello Martin,
See attached file.
please upload you pentable file.
Also ... your config.pro file must contain following option:
pen_table_file absolute_path_to_pentable_file
Martin Hanák
kdirth
(To:GR_6261265)
Try this config:
GR_6261265
(To:kdirth)
Wooowww, Thank you very much it works, now hidden lines looks dashed as it should be.
Thanks a lot. 👍
You've apparently marked your response to the solution *as* the solution.
