Decimal places not displayed correctly when set to limits.
lnick
Hello all,
All of our dimensions are three place by default, but occasionally we have some two place dimensions. When the tolerance of a two place dimension is set to limits, it shows on the drawing with three places. This only occurs for dimensions that are driven (which are almost always used). If a dimension is created (inserted) in the drawing, it displays as it should (see attached). I have looked in the drawing options and the config file, but didn't see any settings, that jumped out anyway. I have been told this is a bug in the software, but was curious if anyone else has come across this issue. Wildfire 3, M120. Perhaps this was corrected in a later release...
Thanks in advance for any help/input.
0 REPLIES 0
