Decimal places shown in a repeat region
GregMerz
7-Bedrock
WF 4.0
What I want to do:
Show a family table driven dimension in a tabulated table on a drawing. Column 1 is MM, column 2 is Inch.
In Part:
Units are MM.
d1 is in the family table
properties for d1 is set to 3 decimal places
parameter: DIA_INCH
relation: dia_inch = d1/ 25.4
In Dwg:
table w/ two columns
individual repeate regions for each columns
filter set for column 1: &fam.inst.param.name == d1
filter set for column 2: &fam.inst.param.name == DIA_INCH
Problem:
I need to have the MM column at 3 deci places (controled by the properties for the d1 dimension), but how do i get the Inch column to display at 4 deci.
I know about the &param_name[.x], this only works in a note.
Thanks for the help
Solution:
Properties of the first cell in the repeat region "&fam.inst.param.value[.4]", does the trick.
