Defining a Sketch
ptc-2819933
Defining a Sketch
I have drawn up a border/frame with geometry. I want to define this as a sketch to pull from the template browser. I go to Create sketch and then I pick a point and the little dot shows up in the viewport. Then I go to Define the sketch and this is where I'm lost. All it does is select the dot, it won't select all the geometry. The help menu says a sketch can be created from geometry, and I follow the ambiguous steps provided, but nothing works. Is it because I have already drawn the border/frame? Do I need to draw it after I create the sketch reference point? There must be a way to make established geometry into a sketch. Any help would be awesome, thank you!
0 REPLIES 0
