Delete a feature in creo pro program
VS_10114209
2-Explorer
I have a question regarding the deletion of a feature in Creo Pro Programming.
I have created a parameter called BOSS and I am trying to run the below code.
IF BOSS==YES
DELETE FEATURE (initial number 😎
INTERNAL FEATURE ID  123
PARENTS = 2(#1) 6(#3) 4(#2)
ENDIF
I am able to delete the feature irrespective of the value I give to BOSS Parameter.
The questions are as follows
  1. Does Creo Pro Programming allows me to delete a feature depending upon the parameter value?
  2. If the above question holds good what is the correct syntax to use the delete command?
Suppression is happening if I try to use the else or add statements but I want deletion.
Thank You,
tbraxton
(To:VS_10114209)
Pro/Program does not support deletion of features, only suppression.
Involute Development, LLC
Consulting Engineers
tbraxton
(To:VS_10114209)
Hello @VS_10114209
It looks like you have a response from a community member. If it answered your question please mark the reply as the Accepted Solution.
Community Moderation Team.
