Different Color Surface from One Side to Another in Creo Parametric 2.0
ehjorten
2-Explorer
I know you used to be able to do this in previous Pro/ENGINEER versions...when you colored a surface it would ask you if you wanted to color one side, the other side or both sides.  Can you still do this in Creo Parametric 2.0?  I can't seem to make it work!  I have a previous model that has a quilt that is colored green on one side and red on the other.  I can't re-create this in Creo Parametric 2.0.  I know that I can make 2 surfaces with a very slight offset and make it work, but I should be able to make this work?
ehjorten
2-Explorer
(To:ehjorten)
With some extra help I did find this:
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS31449&lang=en
And I verified that it worked.  The <Alt>+<select> took a little bit to figure out.  <Alt>+<select> then when the arrow comes up, release the <Alt> key and you may click on the arrow to alternate sides.
