We're new at this! Can someone tell me how to place a drawing dimension for a chamfer so it displays something like .030 x 45°
Thanks in advance.
Hello Charles,
Whenever I am faced with a similar problem, I always use the same approach. If you know the dimension name of a specific dimension, you can reference it in your note. The dimension will then appear with the proper value in the note, and will also update when the dimension is changed. To do this:
- Open your model
- Right click, and select "Edit" for the related feature
- You will now see all of the related dimensions pop up on the screen and reference the model
- Left click to select the dimension you are looking for, then right click and go to "Properties"
- Open the "Dimension Text" tab at the top
- Near the bottom in the name field, you will see a value, d106 for example
- This is the name you are looking for
- Go into your drawing, and in the note you want the value you appear, type &d106
- When you complete the note, you will see in the place of &d106 that the value of the dimension appears
- You will have to add the º (degree) symbol manually since notes do not have the same properties as dimensions in the drawing (e.g. you cannot change the tolerance of a note, you'll have to put it in manually)
