how can I divide in my drawing the part list in two columns? The list is too long and doesn´t fil in the drawing and would like to have it in two columns.
Thank you!
Best regards,
Edna
Use commands available in menu. To understand their function, use PTC Help Center at http://help.ptc.com
Martin Hanak
Martin Hanak
Thank you ![]()
In addition to Martin's response, after selecting Paginate command in Table group select the location in table to define pagination and Done. Paginated part of table will place on next sheet.
Thanks so much ![]()
