Does a part have to be solid to have volume?
ptc-115314
Pro/E is giving me zero volume on shrinkwrapped parts. Basically any part that is made with surfaces. If I solidify the part I can get a volume but not before.
So, does a part have to be solid to have volume?
AFAIK: yes. However, Pro/E is pretty good at automatically solidifying imported surface sets that form a closed volume, so my guess is that your surface set has some leaks (and it would therefore be impossible to define an enclosed volume anyway).
You could test by opening the shrinkwrap and, if it’s appearing as surfaces (cut a section or use View->Display Settings->Visibilities [WF4]) then add a Solidify feature and see whether it works.
HTH,
Jonathan
