I was informed that I need to write a java function to apply to a report field to be able to count devices for a BOM. Does someone have it to share?
I thought this resource should be available, has it is basic to generate a BOM and it is present is every schematic software I know.
This is very much available. I do not have Proe open now. As I recollect. Select the repeat region-->Attributes --> Recursive --> no repeats.
and then min repeats --> -1 [to prevent blank rows]
Hello Srinivasaniyer.
Thanks for the answer but this is not about ProE, but Creo Schematic, formerly RSD.
Could you help about it?
Sorry. I cant help you there. I don't use RSD / Schemetic.
Hi Luiz...
A special community just for routed systems (piping/cabling and schematics) users is under discussion here at PTC Community. In the meantime, you may be able to find the help you need from some of the people over at www.rsdesigner.net There's a following of schematics experts over there that may be able to help you.
Good luck!
-Brian
