Drawing import/merge
cdown
7-Bedrock
Guru's,
Not to sure if this can be done I'm guessing not. I have an assembly drawing of a sheet metal frame. All of the sub parts have their own detail drawings, however it has now been decieded that all the detail should be on the assembly drawing as different sheets, is there a way I can merge drawings / import drawings or will I have to go through and add all the veiws in again (I'm guessing the latter!!)
Regards
Colin
kimndave9
(To:cdown)
You are looking for Import Drawing/Data, which will bring in what you want.
x
