hey guy i have a problem with drawing......i have a complicated model with a revolved feature as a base feature. And when i'm working with drawings i am in need of showing the section which i could not acheive by any sectional types....So i decided to create a sketch with that drawing and combined view reps to filter out the section alone in the drawing...
The problem is that when i print the drawing i noted that the drawing view with the sketch alone is not clear and even some entity was been missed in the print. All the other views created directly from the model are perfect....i don't know why this thing happens..can anyone please help on this issue??????
try changing between truetype font and stroke all fonts, in the print settings under the printer tab.
You have to upload pictures and Creo data, if you expect community help.
Martin Hanak
