Drawing print issue
vishnu.chodavar
Drawing print issue
I am facing the problem in printing the drawings. The drawing view is made of all curves. All the layers are properly controlled ane even the line style checked. But i was unable to get the print properly, some lines are not getting printed. If i close pro/e session and reopen pro/e i am able to get the prints for very first time. From the next time, the problem repeats. The same way, if i reload the config file, i am able to get the prints. The problematic part is, every time I need to either of these two things to get the PDF print and hard copy from the printer also. Please suggest me alternative technique or root cause. Thanks in advance for all your time and support!!!
0 REPLIES 0
