EFX / AFX
gbon
EFX / AFX
Can someone tell us what are the capabilities and limitation of ''EFX lite''
that is include in all packages?
What can be and cannot be done with it?
Perhaps there is a web page that explain this?
GB
JimBarrettSmith
(To:gbon)
Hi
AFX Lite is available from Creo Element Pro 5 M010 using configuration option efx_enabled or if using Creo 2.0 afx_enabled
* All commands, features and functions are accessible
* Full access to comprehensive library
* Fully upgradeable to full version
* Limitations are
o 20 Profiles / equipment (plates, castors etc)
o 10 screws or dowels
o Import/export to neutral interface
Jim
mganzer
(To:gbon)
FYI on Lite modules:
CS130029.
  • Digital Human Modeling: Manikin Lite
    • Any Creo Elements/Pro user may load, place, edit placement and manipulate a
      manikin in the scene, with the following limitations:
      • Limited tools for manipulation (2D drag and apply posture only)
      • No ergonomics analysis; no reach envelope; no vision cones and no vision
        window
      • No ability to save designs that include a
        Manikin
  • Expert Framework Extension: EFX Lite
  • Structural analysis: CAE Lite
    • Guiding interface walks users through model setup
      • Static Structural Analysis for Parts and Assemblies
      • Apply Loads and Constraints (Displacement, Pin, Ball, Planar)
      • Full results functionality
        • Results Probing, Animation, etc…
    • Leverages Creo Elements/Pro Mechanica technology
    • Complete upward model compatibility to the full version of Creo Elements/Pro
      Mechanica
    • CS 16995 Pro/ENGINEER Mechanica Lite application: Capabilities and
      FAQs
  • Electromechanical analysis: Spark Analysis Lite
    • Provides the ability to analyze electrical creepage
      • Between two selected parts or quilts
      • Clearance analysis disabled
  • CAM Lite
    • Basic 2 ½-axis milling capabilities, allowing machining of prismatic parts
      in 5-axis positioning
    • Intuitive UI that is completely icon/dialog driven (no menu manager)
    • Provides a generic (Fanuc) GPOST, so that the user can see example G-Code
      output; only CL file output
    • Specific GPOST can be purchased from AustinNC or other vendors
