We are aware of an issue causing intermittent login problems for some users following a recent update. Learn More
Introduction of EMX Component data file
sir plz add more comp_data file for diff. component..
The contents of comp_data files are similar (components in tab "EMX Components") You can update the existing files to get what you want. If you want to develop different components, you have to use "Component Editor" to create 'Library' components.
