Error In Relations in Part Modelling
SM_9791973
I have Used certain relations in creo 4.0 as i am trying to drive the dimension through excel so i have created relations in the excel which i tried to import in the creo and I also change the name of feature id's then also while giving relations between them i am having error like invalid symbols or the relations have errors. I have made simple assembly which contains 2 parts :- (1) part 1 contains the sketches (work as skeleton model) (2) part 2 contains the extrude (length of the box) & depth of the hole (extrude cut in the box)
Relations are as follows:
HOLE_SIZE_E=HOLE_SIZE_B:1
HOLE_DEPTH_E=HOLE_DEPTH_B:1
BOX_WIDTH_E=BOX_WIDTH_B:1
BOX_HEIGHT_E=BOX_HEIGHT_B:1
BOX_LENGTH_E=BOX_LENGTH_B:1
HOLE_SIZE_E is given to the part feature(dimensions) while HOLE_SIZE_B:1 is given to assembly relation
pl. can anybody help me to resolve this error...
Shubham Mehta
0 REPLIES 0
