Hello @dtrabattoni
You'll find an example "ready to be downloaded for use", and also a very clear guidance on how you can "tune" it starting from stepc described in our article 70231.
=> Once done, remember to add bom_format option in config.pro, and provide as value the full path and name of the BOM source file (*.fmt).
Hope this helps,
Serge
Hello @dtrabattoni
Hope this helps,
Serge
THANK YOU SO MUCH !
