Hello!
I have a customer that I export sheets into individual DWG (or dxf) files for, the sheets are one component per sheet (what they want, makes for a lot of sheets) and they want the DWG files named by the detail number (part number). Is there a way to automate the export to have it change the names of the DWGs (link to a parameter or something)?
Also, is there a way to bulk export all the sheets. I made a macro to do it per sheet, but there's about 120 sheets( 2 jobs ~60 sheets each).
thanks!
