Hello, is there a method to know the file size in Mb of an assembly or part in creo or in windchill?
Tank you,
Michele Barile
Open a model in Creo
Run ModelCHECK in interactive mode (File > Prepare > ModelCHECK Interactive)
Expand Information section in ModelCHECK report
There is FILE_SIZE parameter with the file size.
But in bytes, not Mb
If the model exist only in-session i.e. the model not saved yet
the FILE_SIZE will be with 'error' value
In Windchill
open a model page
open the 'Content' tab
see File Size in kb in the 'Primary Content' section
The only way I know of to tell the file size of a part/assembly is to write it to disk and see. I don't see any means of obtaining this information from a part that is currently in session. Maybe this kind of info isn't offered because it's somewhat unknown until the file is written. Creo files are compressed when written to disk, I believe.
In Windchill
open a model page
Within Windchill PDMLink, If you view the details of a part, you can look at the "content" tab or the "history" tab, it will tell you the file size.
