All,
Up to Creo 3.0 - whats the latest and greatest solution for having instances being differing colors?
I recall seeing something in the past that may have involved adding surfaces?
But I just bet it's easy in 3.0.........................NOT! LOL.
WayneF
Hi Wayne,
I found an article that may address the issue. Please take a look at the following:
CS33983 - Is it possible to assign a different color for each family table instance using Material Appearance in Creo Parametric?
If you are unable to access the information, the resolution listed is as follows:
Amit
Hi Wayne,
Amit
Thanks Amit! I copied surfaces and tabled the surfaces.
There is another Workaround #3:
- Add a extrusion that removes the existing solid
- Add features that copy the original solids
- Paint the new features in the desired color
- Modify the table to suppres these features
Comment 1:
Make use of a component interface on features who are never suppressed to avoid problems when replacing parts.
Comment 2:
You can modify the program of the part to avoid a lot of collumns in the family table. This way less errors can be made when adding a extra component. For example, if "BLACK" is in the Parameter "TITLE", unsuppres the following features.
