Hi
I am creating a family table is pro e.
In that i will be modifying sd0,sd1,sd2...etc etc..
Its hard to remember what parameter is this..,every time i go to wire frame and knowing what it is.
Rather if i rename those with what i want,it will be helpful for me to remember what dimension it is in that model.
say for examle,i want to rename sd0 as Length,sd1 as Width,sd5 as Flange Fillet some thing like this..
Is it possible in proe to rename these Sd0,Sd1..???
Help me Guys
Regards
Saravana
Hi
Yes it is possible
1. double click on the feature(extrude,revolve etc)
The dimensions will be visible
2. Right click on the dimension, and go to properties
3. Change the value of name (sd0 to length)
(Remember not to give space between words)
Regards
K.Mahanta
Hi
Yes it is possible
Regards
K.Mahanta
Hi
That was really helpful
Thank you so much
Arigatho gosaimas ![]()
Regards
Saravana
