Find in a mapkey
davehaigh
Find in a mapkey
I'm trying to create mapkey that creates a mass property feature and then writes a relation for that feature.
Find is not selecting the feature. After Find, hi-lites the feature, I try picking the ok button from the menu that the feature relations pick put up, but it doesn't select the feature.
Same problem using both the new relations UI and the old UI.
Anyone know how to get this to work.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
davehaigh
(To:davehaigh)
Go to Tools, Relations, change the pull down menu to Feature. You get this menu:
[cid:image001.png@01CAFCD4.F460C790]
Then pick Find. How do you get what you found, as the selection for the feature relation?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
