Hello, I am trying to have the value of a parameter (defined as a varied or "flexible" item) within a part be assigned the value of a parameter in an assembly the part is placed in. I have set the "Assoc. Param" field for the component's varied item parameter to be the name of a parameter in the assembly, but the varied item parameter does not take up the assembly's parameter's value--it uses the "new value" in the varied item row. I've looked everywhere I can think of for more details on exactly how these "associated parameters" are supposed to work, but they just don't do what I think they are supposed to do. Anyone have experience with them, or know where I should look? Many Thanks, Bill.
