Flexible components become inactive when dragging and in mechanisms
jbush
11-Garnet
This is the first time I've tried using flexible components in a mechanism assembly. When I click "Drag Components", or go into Mechanisms application, the flexible components become inactive in the model tree and disappear.
I assume this is normal behavior and no way around, but wanted to confirm with folks before I go back to saving a bunch of separate parts with different states of compression.
Creo 2
Thank you!
0 REPLIES 0
