Gears Connections | Creo Tutorials - All in One
VladimirPalffy
Gears tutorials include base steps: How to create gear connections in Mechanism mode and definition of gear properties, analysis and animation.
You can capture the following motion relationships using generic gears:
  • Rotational/Rotational
  • Rotational/Linear
  • Linear/Rotational
  • Linear/Linear
Examples of the four dynamic gear types include:
  • Spur — Two meshing gears rotating on parallel axes
  • Bevel — A pinion gear driving a crown gear on perpendicular axes
  • Rack and Pinion — A pinion gear meshing with a sliding rack gear
  • Worm — A worm shaft rotating a pinion on perpendicular axes
Best Regards,
Vladimir Palffy
0 REPLIES 0
