All,
I have almost never used the Geometry Check feature in Pro|E unless I have a feature regeneration failure. If I don't have a feature regeneration failure, then why look? Right? Maybe wrong...
There is ONE major thing that I avoid in Pro|E: CIRCULAR REFERENCES
If I create a circular reference, then I do whatever it takes to eliminate it. But how about Geometry Checks? Should I hate and avoid them as muchas circular references? My models are working great! I can redefine, modify, regenerate, assembly, mirror, etc. without any problems whatsoever.
Should I be concerned?
Wildfire 4.0, M070
Sincerely,
Neal Rosenblum
Geometrix Engineering, Inc.
201 N. 13th Avenue
Hollywood, FL 33019
Ph:954-920-2049
Fax: 954-920-9574
Cell:954-649-9399
<u>neal@geometrixeng.c</u>
