Hello Everyone,
We are working on an assembly having lots of sublevels. While creating some relations , when try to "Insert" -> "From List" , it shows the error message "Requested filtered table exceeds the number of allowed rows.Re-edit the filter or cancel."
Please help me to solve this issue.
You will need to create a custom parameter table filter.
From the ribbon select tools > parameters then on the right hand side of the parameter window select customize.
After you have created your filter you can go back to the relations window. If you can't see the drop down list for the parameter filter, select edit>show filter
Could you explain step by step with image?
