Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Gtols
kwsauter
Gtols
I've got an ASME 1994 datum tag that refuses to move from a side view to
the end view I want it in. I used a feature datum axis (the revolve
axis in this case) to create it, But it's very squirrelly in the way it
behaves. I can't rotate it around the revolved feature unless I edit
attachment, and now it is showing up in a side view (of the cylinder it
was created in) and not in the end view of the cylinder where it should
(IOW, it rotates round and round in the side view when the round end of
the cylinder shows in the other view). RMB doesn't give me the choice
to move it to another view, and I can't find it in the model tree to
change its name and use something else. I'll be happy to create a datum
axis that I can name what I want, but I have to get rid of this one
first.
How do I find it or move it?
Ken Sauter
DRS Reconnaissance Surveillance and Target Acquisition
Infrared Technologies Division
PO Box 740188
Dallas, TX 75374
469-221-5430
NOTICE: This e-mail transmission (and/or the attachments accompanying
it) may contain confidential or proprietary information belonging to DRS
Technologies or the sender. The information is only for the use of the
intended recipient. If you are not the intended recipient you are hereby
notified that any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this information is strictly
prohibited. Any unauthorized interception of this transmission is
illegal under the law. If you have received this transmission in error,
please promptly notify the sender by reply e-mail, and then destroy all
copies of the transmission.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior written approval from the U.S. Department of State."
0 REPLIES 0
