HELP reverse engineered surface deviation
al204
Hello Folks,
I´m playing with the REX module.
I´m creating a surface over a faceted model of a human foot.
The method I´m using to generate the surface is the automatic surface generation tool.
My problem: I can´t measure the deviation of the surface vs. the faceted model.
I have created other surfaces using curves and analytical tools, and the deviation measurement does work in those instances.
is this a problem only of the surfaces generated by the automatic tool ??
any thoughs are appreciated
al.
0 REPLIES 0
