Dear Experts,
I have several assembly's which contains 50 - 100 components. As of now i am manually creating the explode view of the top level parts. Is there any way i can automate this Explode Assembly process, Because its taking too much time for us.
Any suggestion's will be really helpfull.
With Regards
Aghil.M
The Default Explode produces poor results.
It can be helpful to use "move with children" and to set the movement increment.
Creo has no "Explode like I would, but faster" setting.
50-100 components should take between 30 and 60 minutes. Is this how long you are taking?
