Help required in Dynamic analysis.
susovonsur
I have a requirement of analyzing a small structure, measuring around 2000mm X 400mm. The structure is subjected to vibrations along the X & Y axes. Also, loads are applied on top of the structure. What process should I follow to determine the dynamic analysison the structure.Given: Dynamicload value as an input in Kg. While the static forces obviously dont pose any problem, I am moreegar to know the procedure for getting the vibration part defined properly. Do I need to do a modal analysis followed by some other test? Please help! It's very urgent.
0 REPLIES 0
